STOP 0x0000007B error message in Windows
Hi TechyV buddies!
I am having some trouble with my PC getting blue screen or what is well known as BSOD. I am not certain of what caused this but I have a guessed that these issues are caused by viruses, but I am not certain of it.
Here are the following errors with blue screen:
A problem has been detected and Windows has been shut down to prevent damage to your computer.
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again follow these steps:
Check for viruses on your computer. Remove any newly installed hard drives or hard drive controllers. Check your hard drive to make sure it is properly configured and terminated. Run CHKDSK /f to check for hard drive corruption and then restart your computer.
Technical information:
STOP: 0x0000007B (0xF78D2524, 0xC0000034, 0x00000000, 0x00000000)"
Can anyone help me solve these problems?
Thank you!
