genesis
Posted on - 07/22/2011
     My pc had encountered terrible problem. When I boot it I got a Blue Screen of Death (BSOD). It says STOP ERROR 0x00000024 NTFS_FILE_SYSTEM. I tried to boot it in last known good configuration but it did not work. I also tried to boot in safe and still had no luck at all. I asked my friend to slave my hard disk in his pc. The disk has no problem when I checked it. I tried to run chkdsk but still no use. It was functioning properly yesterday and got no problem. Can anyone help me? I don't know what to do.
ayegired
5 points
STOP ERROR 0x24 NTFS FILE SYSTEM
This message shows that a problem occurred within Ntfs.sys, the driver file that allows the system to read and write to NTFS file system drives.
One possible problem is a malfunctioning SCSI and Advanced Technology Attachment (ATA) hardware or drivers. This can also adversely affect the system's ability to read and write to disk, causing errors. If the computer is using a SCSI hard drive, check both for cabling and termination problems between the SCSI controller and the disks. You will need to periodically check the Event Viewer for error messages related to SCSI or FASTFAT in the System log. You can also use Autochk in the Application log.
Try the following. First, Double-click My Computer, select the hard disk you want to check. Then, on the File menu, click Properties. Then, click the Tools tab. Next, in the Error-checking box, click Check Now.
Finally, in Check disk options, select the scan for and attempt recovery of bad sectors check box. You can also select the Automatically fix file system errors check box.
Kirk25
5 points
ATA?IDE drive error. To solve this ,Check for cabling problems, check for loosed or twisted cable, cabling terminating problems as this can affect the ability to read and write to disk. Also periodically check Event viewer for error message related to SCSI in the system log.
Or if nothing happens you can troubleshoot this by yourself manually to see the detailed problem.
(Blue ScreenView), (MyEventViewer) and (Faultwire) is a free software which is an excellent tool for posting Blue Screen Error Information .It read minidump(a small core dump comprising a memory depending on your system) and it can also note the time and BCCode(also same as stopcode)Â this is a bug error code, example if you received a BSOD.
To apply this software:
Run Bluescreenview>Run MyEventViewer a simple alternative of the EventViewer of windows and check for entries look at the code on faultwire.
Faultwire can view the error code such as this 0x00000040 to 0x0000007F. Now you can post the BCCode or Stop Codes, Parameters which is more detailed.
Janine08
5 points
Hi Genesis.. 🙂 Here are some steps to solve:
First, make sure that you have this error code – Stop 0x00000024 or NTFS_FILE_SYSTEM.
2 This message shows that a problem occurred within Ntfs.sys, the driver file that allows the system to read and write to NTFS file system drives.
3 One possible problem is a malfunctioning SCSI and Advanced Technology Attachment (ATA) hardware or drivers. This can also adversely affect the system's ability to read and write to disk, causing errors. If the computer is using a SCSI hard drive, check both for cabling and termination problems between the SCSI controller and the disks. You will need to periodically check the Event Viewer for error messages related to SCSI or FASTFAT in the System log. You can also use Autochk in the Application log.
4 Try the following. First, Double-click My Computer, select the hard disk you want to check. Then, on the File menu, click Properties. Then, click the Tools tab. Next, in the Error-checking box, click Check Now.
