STOP – Error Dism Mount-Wim
Hello TechyV!
Hi, TechyV! Can anyone please tell me how to fix this error?
I can't find any resource on the Web dealing with this.
Any help would be greatly appreciated, thanks!
STOP – Error Mount-Wim
Dism Mount-Wim return with error code: 1058
 Error Dism probably due to previous use of imagex 6.0.6001
 Reboot and then Remake using the Collected Win7 Files
OK
Best Answer by Mcdonald Larimore
Answered By 0 points N/A #93351
A few things,
1. Make sure you are using DISM from the Windows PE Tools Command Prompt, and not the regular command prompt.
2. make sure you have full control permissions on the directory your MOUNT folder is in, as well as the location of the WIM file you mounted.
3. Make sure to run the prompt in #1 as Administrator.
It looks like you are running this on Vista right?
Answered By 0 points N/A #93352
Hello FrancesHB,
There is an alternate solution to this problem and you should consider it to be sure that this problem is solved once and for all. You need to follow these steps:-
  • First of all, make sure that GImageX is close.
  • Now open Regedit.
  • Go to ‘HKLMSoftwareWIMMountMounted Images’.
  • Locate a sub-key with big name like ‘375cf017-f246-432d-9643-e5b1082617d0’ and delete it.
  • Close and re-open windows Explorer.
  • Delete the folder that you used as mount point (e.g. <C:JOBWIM>) and then recreate it at the same location.
  • Re-open GImageX.
The problem is solved now.
