Stop interruption of screensaver while watching movie without disabling screensaver
I want to know if there is any solution to stop Screen saver interruption, while watching a movie without disabling the screen saver?
There are several ways to get rid of this problem. Some media players can automatically turn off screen saver.
In media player, right click at the top on the title bar, there will be a menu, select tools then options, click on the player tab and unselected, "ALLOW SCREEN SAVER DURING PLAY BACK".
In VLC media player, select video setting and check, "Disable screen saver'.
In Windows Media Player, get player option and uncheck the box named as, "Allow Screen Saver During Playback".
In KMP player, go to the preferences menu; then in General settings select the general tab and check, 'prevent screen saver'.
If none of these work, you can use "mouse jiggler" that moves the mouse pointer back and front sometimes, to prevent screen saver from becoming active or "Caffeine" is another option for you, which is like jiggler but stimulates key strokes instead of mouse pointer movements.
Just download it and the use is very simple.
Yes there is a solution for that.
Hi good day,
To disable the screen saver:
Your problem will be solved.
Enjoy watching movies. Hope its helps.
