‘Storage is not available’ and the error code is 10.
I am facing problem with the photo uploading. I can upload the photos with 1600 pixel but it does not allow me to uploading with its original size. Those images are sized around 7 ½ MB and 16 Mega Pixels. The Picasa is allowing both the features. But it is not allowing its original size as it says ‘Storage is not available’ and the error code is 10. Even though it is showing error message, the images are uploaded successfully and it is viewable. But it is not allowing me to upload multiple images in a single time.
Please guide me.
Thanks in advance.
Best Answer by Pantra Glory
Answered By 0 points N/A #83995
You can fix your problem by Registry Cleaner. Actually error code 10 is a Device manager error code,it's called Windows Device manager error code. It's occur when the device manager fails in error occur. I told you first that,Registry cleaner can fix the problem. You have just need to download Registry Cleaner. After downloading,install your download file and scan your Registry with it. Let it fix the error code 10 issue.
Now you can upload your photos. If it is 1600 pixel or 16 mega  pixel,It couldn't create any error code or any problem issue. So please try it now and get free from this problem.
Answered By 20 points N/A #83997
Dear Kamal,
This has been a repeated problem and have been found across the board on all platforms. There has been a huge discussion on Google forums about it and to date this problem has not been fixed. You can read the logs of long discussion on the Google Picasa forum here. If you have a paid account I suggest you contact Picasa support for a refund or immediate solution of that problem. I have not been able to find any solution on any forum for that error. Eventually,you can try other services like Flickr as an alternative.
I hope that was helpful.
Abe.
