Strange communicator issue. Enhanced presence features
I have decided to use office communicator and configure it on my desktop where my operating system is Win XP.
After successful configuration I get the below error message
Office Communicator
You will not be able to sign in because your account is not configured to support enhanced presence features.
Please contact your system administrator
I would like anyone to help me in this aspect by providing proper solution of this problem
Answered By 0 points N/A #123315
In regard with your problem, I don't know the specifics, but, was the office communicator you were downloading has all the requirements needed.
Here are the list of compatibilities, check it if you have it all.
Communicator 2007 R2 and Windows compatibility
Windows Version
Communicator 2007 R2 Support
Windows Vista 32-bit operating system
Supported
Windows Vista 64-bit operating system
Supported in Windows on Windows 64 mode
Windows XP Professional with Service Pack 2 (SP2) or greater
Supported
Windows 2003 Server SP2 or greater
Supported
Windows 2000 SP4
Not supported
Communicator 2007 R2 and Exchange Server Compatibility
Exchange Server Version
Exchange Server 5.5
Not supported
Exchange 2000 Server
Extended MAPI only
Exchange Server 2003
Extended MAPI only
Exchange Server 2007 SP1
Free/Busy information and working hours are available only through Exchange Web Services
Public folders are optional in Exchange Server 2007
Communicator 2007 R2 and Microsoft Office compatibility
Microsoft Office Version
Comments
Office 2000
Not supported
Office XP SP3
Contacts
No presence menu—INFO line only
Office 2003 SP3
Access presence menu
Make voice calls
Reply to IMs
Search folders and notifications
Office 2007 SP1
View presence button
Reply with IM or conference
Tagging
Contextual data
Client Interoperability on Office Communications Server 2007 R2
Current Client Version
Previous Client Versions Supported (with required updates)
Office Communicator 2007 R2
Office Communicator 2007 Phone Edition
2007 release of Office Communicator Mobile
2007 release of Office Communicator Web Access
Office Communicator 2005 (basic presence and IM only)
2007 R2 release of Office Communicator Web Access
Supports interoperability with the same clients as Communicator 2007 R2, above
2007 R2 release of Office Communicator Mobile for Windows Mobile
Supports interoperability with the same clients as Office Communicator 2007 R2, above
Office Communicator 2007 R2 Phone Edition
Office Communications Server 2007 R2 Attendant
Supports interoperability with the same clients as Office Communicator 2007 R2 Phone Edition, above
If you do have all the following requirements, try to uninstall your office communicator and re-install it.
See this steps if you had already followed them:
In Office Communicator System –Standard, you have to (1) Open Setup wizard for Demo (2) Run C:SE_VOLUMEsetupi386setup.exe (3) Click on “Deploy Standard Edition Server” (4) Run Validation test – and leave IE window open.
While in Office Communicator System –Communicator Web Access you only have to Open Setup wizard for Demo and then Run C:SE_VOLUMEsetupi386setup.exe
Once you deployed the OCS 2007 and installed office 2007 and office communicator on the client sides, you should be able to see the presence information control.
Hope this helped.
