Strange errors while booting my Laptop
Hello everyone! I use HP elite book 8440 p and I run Windows 7 on it. So last night I was using my laptop and it was working properly, no signs of any error or hardware malfunction. This morning I woke only to find that on boot I get: STOP: 0X0000007B (0XF78D2524, 0XC0000034, 0X0000000, 0X0000000). What is this? Is this some kind of error? Help!
Answered By 0 points N/A #181192
This is caused by improper settings in desktop computers or laptops. Please make it sure that your software are well updated and checked also for new installed software and device. This usually caused by our hard disk drive settings that cause this error to post in our system. Please if this will appear again, try to launch BIOS Set-up >> look for “Integrated Peripherals” and look for SATA mode. Change the value from AHCI to ATA settings or IDE settings. Save and exit the window and reboot your system. If this will appear again try to repeat the steps mentioned. Restore default settings in BIOS and follow the same steps provided above.
