pat dawson
40 points
Posted on - 05/31/2012
I’d like to discuss a problem regarding an iTunes match bug. I’m not sure if anybody else has observed it. I spotted this while checking over one of my albums in the collection and uploading those to iTunes match.
Every time I click the check box of anthology, I check that it’s working. Then I leave iTunes. But, when I reopen the program, I find that the box remains unchecked.
It was happening with each track I tried to upload. I understand that it’s kind of peculiar. Has this happened to anybody here? I appreciate any knowledge of a solution.Â
Strange iTunes match uploading bug
Maybe this is really not a bug on the program and this is only how the application really works or functions. If this is the first time that you notice this kind of behavior in the program, try restarting your computer then try it again.
If you’re not comfortable with this, try doing a clean installation of the program again and this might fix this thing that you noticed. Uninstall iTunes from your machine then restart your computer when the system requests it.
After booting, check your computer for any possible errors. Use a disk utility application to check the system.
For a much thorough diagnostics on the system, use a disk utility application like Norton SystemWorks, or Norton Utilities. Install iTunes again after this.
If you are not using the latest version of iTunes, try upgrading your application to the latest version. Install iTunes 10.6.3 which supports Windows XP, Windows Vista, and Windows 7. To download iTunes 10.6.3, please visit Download iTunes section.
