Streaming File Error is all I get!
Asked By 7060 points N/A Posted on -
I got an error in a file of MS Exchange 2003 “Enterprise Server” (stand alone). When runs backup (Backup Exec 2010 R2). In last week error appears (Exchange Server) "cannot find streaming file associated with this database". I searched on net and the Semantic site says “There are no spaces in the streaming file “.stm” and EDB” files”, such as (Mail. EBD and Mail. STM). But no issue with the name of file.
Best Answer by Mahesh Babu
Answered By 20 points N/A #81476
I will advice that you check the code to see if there is any errors in the code that are causing the problems that you are receiving. Use a compiler to look for errors in the file that may be causing the problem. Some of this errors include white spaces, some alphanumeric characters that are not allowed in the code.
Check also for errors in the syntax. Wrong spelling of variable and some keywords may be root cause to such a problem. Rectify them if you find them accordingly. Check also the extensions that you have used for important keywords like file names and others.
__
Mahesh Babu
