Streaming video applications on Android
CNET just listed the best Android applications for streaming videos. There is the Crackle, HBO Go, Max Go and others. Are these applications applicable in Asia as well?
If you are referring to crackle, answer is No. as they have officially declared that they have restricted operation to Asian Countries.
But, if you are referring to HBO, there could be possibilities as they have expanded their operations to most Asian Countries too. So you can find more reviews if you search on it further. This could vary depending on the application you are going to use.Â
If you could specify on your desired country, then we could be able to help you accurately on the possibility of usage of such applications.
