String_1.0_beta.32w.exe – Entry point not found
Hi fellows,
I have recently installed chess on my system but when I am trying to run it, it gives me an error on the screen. the screenshot of the error is attached below:
String 1.0 beta.32w.exe  Entry point not found
The message states:
The procedure entry point
??1critical_section@Concurrrency@@QAE@XZ could not be located in the dynamic link library MSVCR100.dll.
I searched this on the internet but found no authentic solution. I am badly stuck. Any help in this aspect would be highly appreciated.
Looking forward to your suggestions.
Kindest regards.
Best Answer by Hubertt white
Answered By 5 points N/A #153192
This problem is caused byMicrosoft Visual C++ Redistributable Package problem. And to fix it you just need to uninstall the application and reinstall it again. By the way, it is better if you are going to use the 2010 version.
For more information just visit http://www.microsoft.com/en-us/download/details.aspx?id=5555
Hope it will help you.
Answered By 0 points N/A #153193
You can download Dll-Files Fixer from this link :
https://www.dll-files.com/client/upgrade/
You will find two options of download free download and full download choose free download by clicking download now, after downloading setup the program and make a scan of Dll files on your computer after finishing you can fix Dll files or it will fix them automatic then restart the application again.
