Hello People,
I wanted to restore on my ITunes and received an error. It is showing the error 29. I tried it several times and several ways but no result. Only the error 29 appears. Have you any idea for the error 29?
Please help me to get a remedy of this issue.
Stuck on Error 29 while Restoring iTunes
Following steps surely help you
1. See hidden files under your folder options.
2.You have to close the iTunes and disconnect your iDevice from your pc.
3.Please go to following directory:
C:Users*UsersName*AppDataRoamingApple ComputeriTunesDevice Support
4.You have to Backup the files available in the folder and delete them from that folder.
5.Lastly put your iPhone into Recover Mode and after that Restore the Custom firmware.
Hi James,
The error 29 that you are receiving is caused by incompatible battery. If you have just changed your battery, you need to make sure that it is the same model as the old one.
You can also try the steps below and see if it will help fix the problem.
For Windows:
Click Start, then go to Programs then navigate to Accessories
Open Notepad or Wordpad
Click File Menu then select Open
Browse to this directory – Windows/System32/drivers/etc
Under File Type, select All Documents
Open "hosts"
Delete everything that has "gs.apple.com"
Click on Save
Try to restore your device again
For MAC:
Go to Applications folder
Then go to utilities folder
Launch Terminal
Then type this – sudo/nano/etc/hosts then press Return
Type in your password
Using the arrow key, navigate to the lines containing “gs.apple.com” entires, then press # in front of the text
Press Control+O to save
Then press Control+X to exit the editor
I hope this will help resolve your problem.
