Hi!
I am just new here. I would like to ask for your help. I got a key stacked in my keyboard. I asked a professional to fix this for me and they said that they have to make me pay $150. I know that they are professional but this kind of problem, I believe that it doesn’t require work. So I just thought of trying to do this by myself. I would like to ask on how to resolve this? Can you provide me step-by-step instructions on how to resolve this? Can you provide me any alternative options if this will fail? Please assist me with this problem, I don’t want to spend money that far from the labor efforts.
Thank You!
Stucked key in my laptop keyboard and tweaking the button
Laptop comes with a flat type keyboard that is not for even medium usage. They get stuck, sometimes got broken or don’t work.
The best workaround of this problem is to use an external keyboard. There are many external keyboards found that are not only long lasting and are of high performance, but hard enough to go many years.
From the market, buy any good USB keyboard that can be connected to your laptop’s USB port and use without much trouble. Logitech keyboards are of good quality and long lasting. Buy Logitech Keyboard.
You can get any other keyboard; from small to large size, from normal to gaming series. But just remember that they should be USB keyboards.
You can also use “On-Screen Keyboard” to type or press the missing or problematic button. From start menu, type “On-Screen Keyboard” and hit Enter.
