joshanne
Posted on - 11/02/2011
I want to delete some messages that got stuck on my taskbar, but there is no command for deletion; I highlighted the messages and used the right-click button, but still, there is no delete command. Every time I try to use my toolbar in opening sticky note, the search results will appear as follows:
Programs (1)
Sticky notes
Sticky notes (windows Sticky notes) (2)
On Monday buy NHL 12
Reminder for pants
Please help me in finding solutions for these problems.
Thank you.
Stucked Messages on the Taskbar Can’t Be Deleted
By any chance are you running Windows XP? If you do, try deleting desktop.htt. To do this, go to search. Filter the parameters to search in Drive C (or whatever letters you mapped your Operating System). Enter *.htt as the search keyword. When it finds Desktop.htt, delete it. After that is you restart computer and see if the changes are made. If your problem still exists, try cleaning your registry. Or if you have the luxury to do so, create another user profile. Using system restore will also help if anything else fails. If all user profiles you have has that same kind of sticky picture problems, maybe a reformat or image state will be the answer.
