Study about the windows XP
Which windows XP feature provides an underlying services that allows windows application to determine when a machine has changed network locations?
Hi Akeshbabu,
Windows 7 version has the easiest way to identify if the type of network location changed because it has auto-display and has pop-up when this occurs.
But here are the steps to change the network location type;
The accessibility of the network you have selected depends on how your firewall has been set on what function should work and not. It has features that let you change the firewall configuration on how Public and Private Network should do.
Private Network has risk because you are setting your computer to allow open communication while Public Network will give you full access of your computer.
To identify the Network Location Type Windows XP should have similar steps mention above.
Dear,
Network Location Awareness. This is that service which is provides underlining service that allows operating system and applications to determine when a computer change one place to another places.
Please click start then click run then type services.msc. Then follow the picture.
Notifications
