StyleGuard fails to install on windows machine with an error
Hi friends,
I am trying to install StyleGuard on my Windows 7 machine and the installation fails to complete with an error that says there was an error while attempting to download the required file. I am using word 2007 on my pc. I tried downloading the installer a couple of times, but find that the required files failed to download. I am using Norton antivirus free trial on my system. Could this be hindering the download in any way? Did anyone else encounter a similar problem? Please give me a solution for this issue. Thanking you in advance for all the ideas shared.
An error occurred while downloading a required file. You may
retry downloading the file or cancel setup.
Answered By 10 points N/A #179709
It seems that your anti-virus program or system setting might be blocking you at the time of downloading the required files. Try to turn off your anti-virus and again don’t forget to turn on after the downloads are completed .Or this may be because, actually your were updating the process instead of installing! However visit here for a proper guide of how to install StyleGuard for windows. Hope this helps in your work.
Answered By 590495 points N/A #179710
Since the problem occurred during the installation because setup required to download a file, make sure your computer is connected to the internet before starting the installation. If you encountered the error again in the future, click Cancel. Check your internet connection first and fix it if there is no connection. Open a website using your web browser to verify that the connection is working.
Once the connection is fixed, restart the installation. You should be able to download the file and complete the installation. If there is no longer a problem in the connection but you are still unable to download the file during setup, try adding the installer or the setup file in your antivirus’ exclusion list so it won’t be monitored during the real-time scan and then restart the installation.
If this doesn’t work, disable or deactivate your antivirus temporarily and then restart the installation. If the installation still won’t push through, while your antivirus is disabled, add the setup file to the exclusion list of the Windows Firewall. To do this, click Start, Control Panel, and then double-click Windows Firewall. In Windows Firewall screen, select Exceptions tab. Click Add Program then select Browse.
Navigate to the location of the setup file, select it, click Open, and then OK all through out. After this restart the installation. You should be able to download the file now and finish the installation. If the problem continues, visit StyleGuard Download then download the setup file again.
