Styler for tuneup logon wallpaper xp doesn’t load automatically.
Asked By 15 points N/A Posted on -
I have installed the utilities for tuneup logon wallpaper xp with the help of TuneUp Styler. The problem I that TuneUp Styler doesn't load automatically, so I can not select the wallpaper for screen I have downloaded. Which settings do I need to make for automatic select the logon screens for Windows xp I have downloaded?
Answered By 30 points N/A #158684
Hello James B Wiser,
There are many things behind this problem. In fact Tune Up Styler is a very useful tool to change logon screens in window XP.
But some time the Logon screen File of Tune Up Styler which is in .tls format, becomes much heavy that window's registry cannot load the file on time to show you.
And one more major problem is a virus. Virus attacks on registry file and makes it unreadable, so the tls file cannot be loaded.
So black screen appears, not logon screen at all.
Please run a system restore to prevent this problem.
I hope you will get the solution.
Thanks
