Hi Guys,
I am trying to create Sub-Pages using wordpress theme but after creating sub-pages those sub-pages don't appear live at my site please any one tell me its solution.
I know sub-pages are supported by my theme but i don't know why sub-pages don't appear.
Sub-Pages don’t appear at my Theme
If you have created a sub page on WordPress and you are not displaying anywhere on the site, what you actually need to do is to place the pages widget on the side bar sub pages which are assigned to the parent pages. Please also be informed that the only theme which display sub pages in dropdown menu is INove. You can try to see your code if there is a line which says display = none. If you have that line, then that would definitely be the cause of your issue. Can you provide your code here for us to check?
