Substitution of strings with seds…
30 points
Posted on - 05/29/2015
How would you substitute strings with sed? May I discover a few examples and allude to them in the substitution string? In the event that the string is 'old' and I run's/old/new', I get 'new old' as the outcome. I require 'new?' How would you supplant an example just on the off chance that it’s discovered, so that its executed faster?
