Suggest any good PDF creator translation tool for documentation work
Hi Experts,
Hope you all good thanks for all your help and support .
I am very busy now a days to make documentation and their pdf translation to doc format,
Please suggest me any good PDF creator translation tool for documentation work. Looking forward for suggestion.
Best Answer by Randolph Brownlow
Answered By 10 points N/A #169444
Hi Groves,
You can use Adobe Acrobat XI to create PDF and translation to DOC format as well, this is a product of adobe company, it is very easy to use.
You can use it as like MS Word.
Adobe Acrobat XI DOWNLOAD LINK
You can get more information from here.
Thanks for asking.
Answered By 5 points N/A #169445
Hello Fred
In order to simplify your work, you can download PDF Creator and install it. Easy to use software and very helpful in this type of work.
If you need, I have also given you a link, that will convert you PDF into Word documents. In case you want to convert first and translate after. This is online and you don't need to download any softwares. PDF-WORD.
Also, I have provided you with a link, and you can use it to translate your documents online. No download required. Just click on the link of Online Translator.
I hope you will find this information useful.
Randolph
