Hi Experts,
I am having 2 Mbps internet surfing speed but the bandwidth limit 5 MB after that surfing speed becomes 256. Please suggest best bandwidth monitor software freeware so that I can keep a track over my limit. Thanks.
Suggest bandwidth monitor software freeware for windows 7
Hello Dear,
Thanks for sharing your problem.
Dear the software that i am going to tell you, is used as a best tool to monitor the bandwidth.
It will show the results 100% accurate.
I think you should try to use Band Width Monitor.
This is the name of software. And here i am giving the link to download this software.
https://sourceforge.net/projects/freemeter/
Please click the above link to download this Band Width Monitoring tool.
I hope you will enjoy it.
Thanks
