Louise Rios
10 points
Posted on - 09/18/2012
My Nokia E 71 battery is not functioning well and was wondering if there is another model compatible with Nokia E 71 besides factory default? If there is any then suggest me best battery Nokia E 71. Any kind of help would be appreciated.
Suggest best battery Nokia E71 besides factory default.
Hello Louise Rios,
Nokia E71 is a wonderful model in Nokia mobile company. That model is compatible with the some other Nokia model. If your battery disturb you very much you can replace your battery.
To replace your battery you can buy your Nokia E71 battery from many sites like:
Thanks
Dear Louise Rios,
Mobile battery is the most critical part in your phone, so when you decide to replace it you should know how much it will costs, but you must buy an original battery, as non-original batteries may harm your phone, but if you have a good original battery for Nokia check on its size to your battery size if they are the same, this old battery is good solution to your problem.
