Suggest the best VFM 32 inch Full HD TV for 32k budget
Hello everyone,
I wish to purchase a 32" LED TV this month. My budget for it is 32K. The LED TV should be 32" LED with full high definition display. Preferably LG, Sony or Samsung but any brands will also do as I am always willing to get the best deal. It should be 3D supported and picture quality must be extremely good. I will hook my external speakers so the sound on the TV is not really an issue. Also, I need it with HDMI connections so I can plug my computer into it for watching movies. Miracast and DLNA is also a plus.
What is your best suggestion for this?
Best Answer by Keith Riley
Answered By 5 points N/A #170232
Hi!
Here is the list of best 32 inch televisions that fulfill your requirements:
1. Samsung UE32F4500 = this television is 32-inch Widescreen. It has one third decreases in its price compared to old version. As you want, it is Smart, which is additional benefit for you, LED television with Wi-Fi ability.
2. Samsung UE32F5000 = this television is also 32-inch Widescreen television. It provides you the 1080p experience of screen. Thus, it is fully HD. It has one additional feature, that is Preview HD.
3. Panasonic TX-L32E6B = It is a Smart LED televison, one of its kind in Panasonic. Even though it has less quality compared to the televisions above, it has the best quality of screen with 1080p. It also has Freeview HD and Wi-Fi ability.
All the televisions above are able to connect with HDMI.
Choose your best television.
Answered By 0 points N/A #170233
Your money is worth with Samsung’s Series 4 UA32EH4000R 81.28cm (32) HD LED TV, USB Movie, HDMI. Currently its price is at 30500, a reasonable price without advance technology being compromised. It has an advanced quality picture, ConnectShare wherein you can just simply plug your USB into the TV to play movies, music and photos. HMDI inputs are also available to provide you a multimedia entertainment.
Also, LG’s Transform LED LCD TV 32LN5150 can be appreciated at your desired price. Likewise, it has the same functions comparable to that of the Samsung.
You might also want to consider Sony KLV-32EX330 32 Inches HD LED Television. The price is pegged at 31004. It also has the specs you look for.
