Suggest better way to record Skype Mac calls.
I do most of my interviews using Skype because my AT&T reception is very bad.
I am looking forward answer to find a better way to record Skype mac calls.
The best way of recording Skype calls on the MAC is by using the Ecamm call recorder.
It allows both audio and video recording.
It comes for about $19.95. You can also try their free demo.
The files are arranged according to the date and caller’s name.
Therefore, it is very convenient to use.
Hello Mike Pincher,
You can also record the audio and video Skype call by IMCapture in MAC operating system.
You can use the trial version of IMCapture by downloading from here:
After using the trial version, if you need the full version, then you need to purchase it.
In trial version, you can record only 2 minutes.
Thank You. Have a good day.
Notifications
