I am using this online converter called audio-online convert. This can to tmp file to mp3 convert. However, after the temp file has been converted to mp3 file, the play back can accommodate less than a minute of music.
I tried to reconvert it using the same process but I am getting the same length of song when converted to mp3. I guess this application is buggy. Can you suggest an application whether web based or downloadable to convert my temp file to mp3?
Suggest fully working software for tmp file to mp3 convert
There is a simple solution to your problem. There are several software which can convert any files to mp3. But I suggest you to use TOTAL VIDEO CONVERTER. This software can be used to convert or make files into your desired format. Click on the below link to download the software.
http://download.cnet.com/Total-Video-Converter/3000-2194_4-10429299.html
Thank you.
Dear Jaycelin Nimbus,
When you are trying to convert a song with five minutes length as an example and when you download it give you an audio with 1 minute only this is not a strange thing. This is familiar when you are using trial version of programs or websites that gives you a small part of your files.
For covering your files freely with no cost you can use format factory it is free software.
https://format-factory.en.softonic.com/
