Suggest me the best anti-virus
Both antivirus has some pros and cons like Kaspersky works both on windows and Mac whereas  Eset Nod doesn’t support Mac. On the other hand, smart rating of Kaspersky is 79% and Eset has 64%. Please see the below link which clearly shows the comprehensive comparative studies of both applications. On the basis of this information, you can better judge whichever will suite you.
https://malwaretips.com/threads/kaspersky-av-2012-vs-eset-av-5.5195/
Hey Denzel morales!
Both of the anti-viruses are the top Anti-virus. However I personally feel that Kaspersky the best Anti-virus I have ever used. Kaspersky is very easy to use and has a very user friendly interface. This Antivirus cleans or deletes the smallest virus in your computer. Not only this Antivirus protects your computer from the viruses but also blocks the attack from other users when you connect to the internet.
In my opinion, Kaspersky 2012 is the best Antivirus and I would like to suggest you to use Kaspersky 2012 for security. I hope you understand it.
Thanks
Tunacao Caaron
Thanks for both of you.. Your comments are very helpful. Probably I would try to have Kaspersky. SInce most of your comments tends to this is much better than the other one… thank you
