Suggest me the best one on earth.
“CyberLink PowerDirector” is said to be the best video editing software in 2012 so far. It is not only my opinion, but, users throughout the world are using this software right now for video editing. One thing that is important to know is what type of editing you are going to do with the software.
If you are a Mac user then I will suggest you another option for this. “Final Cut Studio” can be the best choice for you in that case. You can check that out there https://www.apple.com/final-cut-pro/
There is some other software too I want to mention because they are said to be one of the best video editing software with their specification. You can try “Avid Media Composer” or “Sony Vegas Pro” or you can just try “Adobe Premiere Pro”.
I am glad that you raised your question here and I hope i can help you. The following are the top 5 best movie editing software and you can download it free online and these are the following:
1. Microsoft Movie Maker;
2. Virtual Dub;
3. Pinnacle video Spin
4. Movie storm;
5. Avidemux
I am also a movie editor and I am using Microsoft Movie Maker. I am comfortable of using it and for me it is one of the best. Just select one I mention above. I hope I have answered your question and will you in your endeavor.
Hi Mikee,
There are several video editing software but you must choose the software that is user-friendly and which you are comfortable of using with. The following are the best video editing software according to a website that I have visited and this receives several positive feedbacks:
I hope the information I have given will help you.
Thank you.
