Suggest me a good photo slide show software
Hi guys , can anyone suggest me a best professional Slide Show Software , which will give me a nice slide show
Hello Carly,
There are a number of professional slide show tool that you can choose from. It basically depends on you to pick one according to your preference.
I have categorized the best as follows:
Commercial software:
Freeware:
Hope this helps.
Hello Carly Williams,
I understand you want a software to create slide shows. Try Photodex software that can be downloaded from http://www.photodex.com/ . It has a trial period and you can test before purchasing it. This Software is powerful and creates nice and professional slideshows.
What’s more is that this software will allow you to add video and music in your slide shows and this will make the slides more attractive.
Hi Carly,
There are several great photo slide show soft wares in the market today such as Photodex, PhotoStage Slideshow and CyberLink Mediashow. See here the 2013 Best Photo Slideshow Software. Read and compare the reviews of the top 10 slide show soft wares so you can choose the software that suits you best and will make your slide show stand out.
