Suddenly, I am encountering a 0x8024a112 error in the Windows update center. I am unable to solve the issue. Suggest some ways to fix the 0x8024a112 error while updating Windows 10.
Suggest Some Ways To Fix The 0x8024a112 Error While Updating Windows 10
You can fix the 0x8024a112 error by simply restarting the device. But, make sure you update your device while doing that.
a. Open the start menu.
b. Go to the power option.
c. Select Update & Restart.
d. When the device turns on, the error will vanish.
If the above method did not solve your problem, try the following steps –
a. Press Windows + R on your keyboard.
b. Type Regedit in the box, and press Ctrl + shift + enter.
c. Go to HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Services \ Schedule.
d. Double-click on the Start.
e. Enter 2 in the Value data box.
f. Choose the Hexadecimal option.
g. Click Ok.
h. Restart your device.
i. Update Windows.
