iesha
30 points
Posted on - 07/01/2011
My neighbour has a problem installing his game Sims 2 Bon Voyage. He gets error, it is like Failed to enumerate any.. and all. He has the following specifications:
2GB RAM.
Pentium 4>>3.0ghz>>dual core.
graphics: Geforce 8600GT(latest driver installed)
what could be the problem?
Failed to enumerate DirectX 9 Error on installing SIMS
If the error reads "failed to enumerate any DirectX 9 compatible graphics adapters in this system", your graphics card may need updating with the latest driver, or it may not be compatible with DirectX 9 in which case you will need to fit one that is.
If it's a laptop, fitting a new graphics card will not be possible of course.
Try updating to the latest driver for your existing card. Get the update either from the graphics-card manufacturer if it's a removable card, or from the PC manufacturer or motherboard manufacture if it's a non-removable on-board type.
If you don't know any of those details, download 'Belarc Advisor' and post it's system information log.
