Suggestion About Best Anti-Virus For Me
I have installed many anti viruses but they never fulfill my requirements and also does not satisfied me because they could not detect all viruses.
If they detect any virus then instead of deleting the virus they also delete necessary file.
Now suggest me the best anti virus which could fulfill my requirements.
Best Answer by amannan
Answered By 0 points N/A #99677
Hi aniqa it is very easy solve your problem. At first you have to check out your system that. old one system or new upgrade system and which Anti virus you used on your PC from start being your PC. because it is very important to install Anti virus which can perform better to you. See the below:
  1. Kaspersky is very familiar nowadays it can give you more profit and fast to your whole system. Internet accessories also being update.
  2. .Avast many documents, files have kept and specially Avast Anti virus you can choice for internet connection. It is fast scan system and very powerful management to capture virus.
  3. Avira you can choice for  only Internet connection less PC.
  4. McAfee is also used for whole system based.
you can choice from above one. thanks
Answered By 0 points N/A #99678
  • Actually there is none best anti-virus than you. All you need to do is take care of what you are doing inside your PC. Avoid insertion of removable drives in your PC. Be careful off course on copying files as well as downloading from the internet. This will help you a lot to maintain your PC virus free.
  • For anti-virus software, as per as the survey or review is concern, the best anti-virus so far is the BitDefender Antivirus Plus and next on the rank is the Kaspersky Anti-Virus.
  • For the free anti-virus category, Avast Free Antivirus 5 is on the top rank based on the PC World magazine survey. Next on the rank is Avira AntiVir Personal Free AntiVirus 10 and on the third rank is the Microsoft Security Essentials 1.0
  • The Anti-Virus that I am using, Panda Could Antivirus 1.0 is on the fourth rank on the PC World magazine review. As of now, my computer is free from virus infection. Not because of panda, it is because I care for it.
Answered By 20 points N/A #99679
Visit this Techyv article. There you will get 5 best highly recommended antivirus software which are able to fulfill your requirements.
5 Best Highly Recommended Antivirus Software
