Suggestion about joomla virtual pet module
I have a Joomla site.
I want to create a virtual pet shop.
Any kind of suggestions regarding Joomla virtual pet module would be highly appreciated.Â
You can us use any standard e-Commerce extension for Joomla. E – Commerce extension is a great one.
You can also use VisualMart. Which one you should use is depend on what you need.
You can explore different Joomla extension and if finalize any one you can moreover customize the extension based on your need.
I had great experience with VirtueMart shopping cart software for my jewellry online web-shop.
It is so easy for use and configuration. Â
What’s best – It’s free! And one another thing – There are hundreds of (free&commercial) VirtueMart-specific extensions.
You can download VirtueMart component from this location.Â
