janssen
430 points
Posted on - 06/12/2011
Hi there,
I am using
Emaxx motherboard
AMD Sepron(tm) processor LE-1150
2.00 GHz, 1.43 GB of RAM.
I love playing online games, and at the same time I have online jobs. Any suggestions for the best motherboard for me? and what memory RAM do I need to upgrade? Online games is my past time, while I'm not working. Some of my friends told me that INTEL is not good for online games, coz INTEL needs to have video card while EMAXX doesn't need video card just upgrade the memory RAM. Is it right? Please guys need some suggestions. Thanks a lot.
Suggestions for best motherboard for games
At present you are using Emaxx motherboard with 1.43 GB of RAM. To get extra memory space you need to use extra RAM with additional memory. You can fix it on the available slots of the motherboard. You can also collect suitable motherboard from the market as per your requirement. You know that there are various kinds of motherboard available in the market with different configuration. So you should collect the right motherboard for you. I can suggest you to use Asus SABERTOOTH Z77. Why?
On Board Video – CPU Dependent Video
Memory Form Factor – UDIMM
Memory Technology – DDR3 SDRAM
Number of Memory Slots – 4
Maximum System Memory – 32GB
System Chipset – Intel Z77 Express
Supported Processor – Corei5|Corei7|Corei3|Pentium Dual-Core|Celeron Dual-Core
Processor Socket – Socket H2 LGA-1155
Video Bus – PCI Express x16
The entire configuration mentioned above is very good for high definition game especially for online game and other online job. It is to be mentioned here that this motherboard is supported by INTEL Z77 Express System Chipset.
Best regards,
Heather marie
