I just decided to NTFS format my 16 GB Corsair Flash Voyager GT Turbo USB 3.0 Flash Drive.
My OS is XP 32 bit and when I try to format, it says "Windows was unable to complete the format".
It seems like it has a FAT32 Partition.
Any suggestions in Corsair usb flash format?
Suggestions in Corsair USB flash format needed
Hi Trevor Weiss,
For your formatting problem.
You may try to format your USB drive on the following process:
Right Click on My Computer.
Click Manage.
Select Disk Management.
After this Click on USB Drive and Right mouse click
Click Format.
I hope this process helps you to format the USB Drive.
Mind that before format backup your valuable Data.
Thanks
Amos Marie
Hi Weiss,
I hope you're doing well. You want to format your flash drive but Windows are unable to complete the format.
I think this happened with the deleting of its primary partition.
If it is the issue you can solve it this way. Click your right button on the my computer and select the Manage then go to disk management from the options.
Select the flash drive from the clicked windows. It may be 3rd window.
Then you can format your drive with the options.
Thank you.
Regards
Kknisely Kate
