karamhobbs
20 points
Posted on - 12/09/2012
Could anyone suggest effective vpn blocker mac could support. In our workplace, some of the employeesuse their mac computer for accessing SNS (Social networking sites) rather than doing their work. They bypass the network through the use of VPN. Your suggestions would be greatly appreciated.
Suggestions for Effective VPN Blocker Mac Could Support
Hello Karamhobbs, Using VPN, users basically access websites with alternative IP addresses. If they are using a single VPN provider most likely the alternative IPs would be in the same block, you can use antivirus software to block the VPN provider from accessing your network. I would suggest you use Avast: Download it from this link: https://www.avast.com/free-mac-security In its firewall settings you can block the VPN provider from accessing the internet.
