Suggestions on retrieving corrupted aiff file
Does anyone have any suggestions on retrieving corrupted aiff file.
I have a few audio files which seem to be corrupted.
I need the file back without any loss of data.
Hi Jones,Â
Your question can be solved, though quite tricky. You may need a software such as the VLC for this which you can download at the website;Â
Once you download, you can follow the step-by-step procedures to install and launch the software.
Open the VLC software and click on 'streaming/exporting wizard'.
Click on 'Transcode' or 'Save to file'.
Click 'Select a stream'.
Click 'Transcode audio' then choose 'Uncompressed integer'.
Once you click 'Next' wav will be the only choice.
Click on 'Select file to save to rename the files.
This should solve your query.
