Suggestions to solve my problems regarding the Bluetooth drivers on Dreamplug
Hi
Everyone! Hoping to have some suggestions to solve my problems regarding the Bluetooth drivers on Dreamplug. It seems they are not working as expected. On an Intel Ubuntu linux, when I use the command-line obexftp client, everything works fine. But this is not the same for Dreamplug. Could the problem be with the bluetooth drivers not being compatible with Dreamplug?
Another thing, I was hoping somebody can answer these too:
1) Is the "btmrvl_sdio.ko" extension the code to get to the BT hardware? If not, can you tell me what it is? Like what file is it or where it is located?
2) When the device attempts to go online and download the recent updates of the drivers, is this supposed to be one of the solutions? Because I tried it and didn't seem to work at all.
If there's any other suggestion or solution you could share with me to make this work on DP, I would greatly appreciate the help!
