ted hitz
20 points
Posted on - 03/15/2013
Hello expert,Â
I have downloaded the HTML calendar code generator to generate my calendar code. But it did not work properly and when generating I got some errors. So, where I can download a suitable html code generator to generate the html code calendar box?
Suitable html code used for the html code calendar box
Hey, Ted.
You can try with the HTML Calendar Maker Pro on the following link:Â
With it, you can create customizable monthly web page calendars very quick and easy.
Also on this link:Â http://html-calendar.winsite.com/Â you can see lots of HTML calendar software depending on your needs.
You can also add a Free HTML Calendar to your website using this link:
First time when you get to your account, click on Calendar in the left panel. Click on ''Customize and Share'' on the blue bar and set the ''Share With'' control to be ''Public'' so your calendar is visible on the web. Choose ''Embed Calendar'' or ''Embed Day Scroll'' on the right side. Adjust any parameters and see the effect immediately.
Free HTML Calendar has different options, some of the displays you can see in the photos below. You can use calendars with horizontal day scroll of 4 days, which is perfect for the iPhone and Blackberry access. You can have month view, week view, day view, event view.
If it doesn't satisfy your need feel free to ask again.
Good luck!
