adam musick
20 points
Posted on - 09/06/2012
I recently installed Windows 7 in my laptop. Before this, I was using the old version of smartcase logon. Now this version is not working in Windows 7 and latest version is not installing properly. How can I install smart care logon patch software?
Suitable version of smart case logon patch
I quite got confused if it is smartcase, smartcare, or smart care. But anyway since the problem started after you changed your computer’s operating system to Windows 7, it’s possible that the software may not be compatible with your present operating system.
To better check this problem, visit the website where you actually downloaded the program and then check its system requirements there. This is clearly a system incompatibility issue and can be fixed by installing the appropriate version that runs on Windows 7. Check the website if the version you have is compatible with your present operating system and if not find a different version that runs on Windows 7. If unfortunately you were not able to find any compatible versions that support Windows 7 then the best solution is to go back to your previous operating system.
