Super zoom camera from FujiFilm
Fujifilm has launched new camera which supports super zoom technology. Using this technology maximum how much area we can zoom ? What will be the clarity of image once it is zoomed?
Based on the review from the Fujifilm X-Pro1 and Fujifilm's X System Lenses, the X-Pro1 has the good votes. Many people wants the X100 because of its transposable lenses and the cutting-edge sensor together with a typically-styled body and reserving the outstanding hybrid optical or a electronic viewfinder.
We had an experience to touch the X-Pro 1 and the 18mm F2, 35mm F1.4 and 60mm F2.4 primes that are presented next to it to know the capabilities and the uncommon color and filter display.
The latest Fujifilm camera model was introduce in 2012, is the FinePix HS30 EXR. This type of new model has a very high optical zoom range up to 30times. The Electronic Viewfinder of HS30 EXR has been improved to lithium-ion rechargeable battery, which is capable of delivering up to 600 pictures per charge. When it comes to the clarity of the image, the FinePix HS30 EXR sensor has been improved, mostly in low light areas. FinePix HS30 EXR has a unique design that allows you to change the characteristics according to the light conditions, and you can redesign the shape of the photo to ensure that you will get a very best result. The FinePix HS30 EXR having a larger features up to 920,000 compared to HS20EXR, making for a far clearer viewing image.
Notifications
