Support extension *.wk4 for Lotus 1-2-3.
I had used excel version 2003 in Lotus notes. Since then excel does not support extension *.wk4 for Lotus 1-2-3. I have now problem to import excel 2010 in Lotus. I have tried all the extension, tabular text and many options.
If there is anyone have faced the same problem or experienced with how to handle this please let me know soon.
Answered By 25 points N/A #107793
I think some people used converters for them to import the .wk4 files to Microsoft office excel or .xls files to lotus 1-2-3. I have researched and found a free program that converts .wk4 to .xls. (Vice versa) here is the download link for the program that you will need to convert the files you wanted for you to do your work https://db.toggle.com/lv/group/view/kl40191/ABC_Amber_Lotus_1-2-3_Converter.htm (download and install the program and after installing run the program)  I hope this will help you in your problem and please tell me if I have solved the problem that you are encountering. Have a good day and enjoy your stay here.
