Support needed for some of the specific procedure in the Outlook
The thing should be in the way as it is described as follows-
- Receiving email from user.
- User should fill up in an active form like PDF, word file etc. For saving and processing documents few fields should be filled.
- As the person fills the document then it will auto go to another person’s email.
So is it possible to create somehow the rules in outlook that could be able to check if the form is filled in and if possible then send this form towards other email?
Could be that was some software either “add-in” for Outlook to make this done. I do not have any idea of “active form” so for making these which would I have to do?
Containing fundamental info as like name, surname, phone number etc.
Could anyone please help me to solve this?
Thank you
