Support for Windows 7’s explorer
NirSoft has released SysExporter 1.60 to create a support for Windows 7’s explorer in addition. How can I manage the contents of Windows 7 explorer windows and Microsoft’s DirectUI?
Berthpeall,
That's a good question you have asked and therefore I believe I can fully assist you in the query.
In order to manage the contents of Windows 7 with Nirsoft, you can just grab the contents of the Windows explorer and you can be able to open and use applications like VLC media player in playing songs or finding videos by just clicking Start > Videos or even minimizing the windows or even copying files from one folder to another or copying a folder structure to another document.
Grabbing especially of many files may take some time but it's convenient in large amount of files or text. It is really convenient even in opening apps.
Nirsoft also allows you to run applications with administrative privileges or advanced parameters and interfaces. This will help your software or programs not to be accessed by any user on the computer.
I hope this solves your query.
