Supported OS For The Camfrog Video Chat Has Stopped Working In Details.
Hello, notify the supported OS for the camfrog video chat has stopped working and the symptoms of it as well and also thank you very much for it as well.
Hey, the camfrog video chat has stopped working can be solved by installing the software related to the same over the web and run over the systems too. There are many Os supported for the same such as in the windows systems such as in windows 2000, windows 7 / vista, windows 8 and many other Os too. The symptoms for the same are as follows:
If Camfrog stopped working on your computer, try to uninstall and reinstall. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select Camfrog among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then install Camfrog back. If this is still the old version and you haven’t updated yet, download the latest. Download the latest Camfrog Video Chat and install it. The latest version at the moment supports Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows Server 2003 and Windows Server 2008.
It requires 1 GHz or faster processor and Microsoft DirectX 9 or newer.
Notifications
