Svchost.exe application error memory “0x745f2780”
Asked By 460 points N/A Posted on -
I get this error
svchost.exe — application error the instruction at "0x745f2780" reference memory at "0x00000000". the memory could not be 'read'
when closed the error box the windows restarts and when left it alone it stays On.
Can anyone help me with a solution. Googling did not help much
Best Answer by Sharath Reddy
Answered By 590495 points N/A #85444
I will need some details is this computer part of the domain. What is the version of Domain and what's the AV solution on the client?
Answered By 590495 points N/A #85446
First thing first disable/remove any softwares recently installed. Like 10 days as this is a single machine issue. I suggest msconfig and remove any new software & unwanted software from there.
Answered By 460 points N/A #85449
Let me try this, Anyways i have windows 2003 domain and my AV is Panda.
Answered By 60 points N/A #85450
Hi Mahesh,
I have seen a lot of sites that is giving some tips and information about this error.
I picked some and attached it in the lower part so that you would have your reference in this matter.
Hope it would help you a lot.
