Hello experts,
I have created an SVG file with Adobe Illustrator and now I can’t open it. I can open any other files in Illustrator, but not this one. It doesn’t contain a lot of characters, is a small project. Can anyone help me to open this file ? How can I prevent this happening again with all of my files ?
Thank you !
The operation cannot complete because of an unknown error. [CANT]
points
SVG file with Adobe Illustrator cannot complete the operation
This is such an error that is happening because somehow, Adobe Illustrator has got damaged system files inside its system. Sometimes it might happen though it is very rare case.
The best way to solve any issue with any software is to re-install the program. In this case, this is also the solution. Install Adobe Illustrator again and it will become fresh. Then you’ll be able to open the file perfectly.
Re-installing Adobe Illustrator worked for me, hope will work for you too.
