Hi there,
While SVP Manager was loading this error appeared and closed the program. Now the program doesn’t want to start at all and the reinstall is not helping at all. Can anyone help me please to fix this error ? What is causing this error ?
Thank you !
SVP Manager
Error preparing smooth playback! Script error:
Write: File ‘C:UsersEricAppDataRoamingSVP 3.1avsFPS.txt’
Cannot be opened.
(ffdshow_filter_avusynth_script, line7)
SVP Manager shows script playback errors
Try starting SVP Manager as administrator. Right-click SVP Manager on your desktop then point to “Run as” and then select Administrator. If you are prompted, enter your administrator password to continue. See if this works. If it doesn’t, try reinstalling the program. Uninstall SVP Manager then click Start, All Programs, Accessories, System Tools then select Disk Cleanup.
Select drive C then click OK. Check Setup Log Files and “Temporary files”, click OK then click Delete Files. Restart your computer then install the application back. Start SVP Manager again and see if it works. If you still can’t open it, try installing the latest version if you happen to be using an older one. Download and install SVP Manager 3.1.6.
It requires Windows Vista, Windows 7, Windows 8, and Windows 8.1. Microsoft Windows XP is not supported. If the problem continues, download and install the patch, SVP 3.1.6 Latest Patch. To install this patch, unpack the ZIP file into the SVP Manager installation folder. But before you install the patch, close SVP Manager first if it is running.
