‘Swann Error Code 10012’ Security In Hand
The Swann is a remote security camera that lets you see and hear what’s happening. It is a wireless system. So, if you’re trying to connect it with your mobile data, you cannot get connected. You can get it worked by going to the settings, click on the “Apps” go to safe home view then click on mobile data. You need to activate the ‘Allow background data usage and ‘Allow unrestricted data usage.’
It is for the Android system, you can now get connected with your mobile data but will take time to connect and is slow. This problem usually arises when the Cisco Call Manager (CAR) user tries to perform a Structured Query Language( SQL) for the CDR database. You should check on the DBL monitor service that is running on the publisher and the subscriber. You should check on the CDR whether it is running properly. You can watch the feeds by adding a Digital Video Recorder to the app Devices Manager Menu. Once it is set properly, you can view your cameras up to 4 at any time.
