I have installed Adobe Flash player to solve the problem of SWF playing in windows media player. Anybody please say, what to do now to change the default opening program of the SWF files from Adobe Flash Player to Windows Media Player?
Swf playing in Windows Media Player
I will help you make a .SWF open in Windows Media Player by default. The first thing you should do is go to your desktop and right click on the .SWF file, then you will have a short pull down menu with options.
Click on the option that says “Open with.”, then a new window will open stating the recommended programs, however you will ignore that and instead click browse at the bottom right corner. A new menu will appear where you can check your computer for Windows Media Player. At the bottom there will be an option called “File Name:” where you can search; there you will type “wmplayer” select it as your default and click “Open” to finalize.
Now, when you click on your .SWF file it will open in Windows Media Player, I hope this helped you find a solution to your problem.
