kent woods
30 points
Posted on - 05/10/2012
Hi!
I am working with new switchable graphic systems. Whenever I try to run the AutoCAD, an error appears relating to the resolution. Please explain why this kind of error appears.
How is this related to my new switchable graphic systems?
How can I resolve this issue?
Kindly provide me solution to this kind of problem.
Error:
AutoCAD-Fehler – Abbruch
AutoCAD lauft nur mit 1024×768 oder hoherer Auflosung.
Thank you!
Switchable Graphic AutoCAD Resolution Error
Hi Kent, the cause of the error is on the resolution, it means the screen does not meet the screen dimension requirements of Autocad. Horizontally, it requires 1024 pixels and Vertically, it requires 768 pixels resolution to run. That is the minimum requirements. You can adjust the screen resolution, on the display option of the windows control panel. Right click on your autocad, choose properties and on the compatibility tab check the NO compatibility and setting option. If your resolutions is not capable to pick higher, it's possible also that you have not installed driver for your graphics card. In most cases, flat screen has optimized resolution, you can not change or else it will get worse.
